Deleted member 9648
duplicate post deleted
For the purpose of an EICR a code 2 would be appropriate only if neither RCD protection or supplementary bonding were in place, if only the latter is present a code 3 is sufficient .I th
ought it was the opposite supplementary bonding could be omitted if conditions were met and under 701.411.3.3 circuits had to have protection by RCD/RCBO.
I rest my case then.I would, but there is a trend towards a view that everything is dangerous without RCD protection which is simply nonsense.
I rest my case then. Argghh its done it again!!!!!I would, but there is a trend towards a view that everything is dangerous without RCD protection which is simply nonsense.
fight fight!your just being f***k stupid now
Maybeyour just being f***k stupid now.
Yes.can we get this post to 100 please!
So you'd code 3 an external socket without RCD protection in an existing property?
The clues in my original post matedepends, does this outside socket already have its own rcd?
A new sticker is required for consumer units.
PLEASE NOTE
THIS INSTALLATION INCORPORATES AN RCD FOR TW£TS WHO DRILL HOLES WITHOUT CHECKING FOR BURIED CABLES
disconnect and remove socket from wall, shove cables in the hole and walk awayThe clues in my original post mate
Nah, replace with RCD socket.disconnect and remove socket from wall, shove cables in the hole and walk away
its the only solution
