Search the forum,
Discuss Testing a socket in the middle of a distribution circuit. in the The Welcome Forum area at ElectriciansForums.net
First post. I've installed a 6mm SWA cable to a summer house in the garden from the house. Summer house has a cu with a ring and light. I've installed an outside socket in the middle of the distribution circuit. Between the house and summer house.
Question. How do I inspect and test this socket and include it on the EIC. It's kinda in no-man's land.
Thanks.
Thanks.
It's not a distribution circuit then is it? it's a supply to a socket with a CU tagged on the end wit a RFC and a lighting circuit as well woulsdn't like to put my name to that.
The circuit on the schedule will state; Garden socket and consumer unit in summer house, points served; 2. Simples but why you did this who knows.
If you don't know how to test and certify a simple radial circuit you shouldn't be doing the job.
Dave it's not really a radial as such it's a sub main with a socket installed in the middle, not an ideal arrangement is it?
I thought that would be the case....I guess I could turn it into a junction box if I have to.
or turn into a
Not the best but you will be hard pushed to find a Regulation to say it is incorrect. Rcd/rcbos both ends I suspect.
Westy the circuit as is, is an abortion, who has ever heard of running a sub main and sticking a socket in the middle? the min boggles.
I would have ran a new cable (swa or pvc pipe) from the cu or spurred off a socket in the summer house, not the best way to break into a distribution circuit to add a socket and now I guess there's two rcds in series, which I hate, because you can't test the 2nd without bypassing the 1st.
Thanks for all your input. I also can't find a reg that says you can't. The socket was already there so the summer house is added. I agree it does all sound a bit shonky..... I'll turn the socket into a junction..... before I put my name to it.
Cheers.
Cheers.
Suggest you read Part 2, definitions, then find Distribution Circuit...
Assuming you have the BYB
Nothing in the regs stating that a distribution circuit can only serve one point.
OK, not under BS7671, but the cable to your house could be regarded as a multi-point distribution circuit.
I've installed one myself. Something like a 60A switch fuse, SWA to separate garage, then continue on to garden office on the same circuit. Made no sense to run two cables or to run the garden office (which was the major load) as a final circuit from the garage.
I have a socket in my loft tapped off the garage circuit which is not RCD protected. Shall I do the honourable thing and shoot myself now?
but can the socket be used to supply equipment outdoors? :(
Hey up Tel.... he did say it's an outdoor socket ;)
SWA does not need an up front rcd. Change the socket to an rcd socket so this sub main is a continuous feed t the summer house cu OR make it a junction box and run new cable to an outside socket? Whatever is best for the location.
i was referring to Strima's attic socket.
Not sure there is a reg saying this can't be done but it brings with it loads of issues such as IP ratings, rcd/rcbos etc.. and discrimination... not sure the part p scams would be too pleased if shown it on a assessment.
I don't see 'loads of issues'.
Suppose you have a radial circuit on a 32A MCB supplying a properly IP rated RCD socket, then on to a board in a shed with RCD main switch. Where are the issues?
That is exactly what it was. Exactly. However, following the general consensus that it was somewhat unconventional, I have changed the socket for a junction. It's part of an application to join Elecsa.....so I want limited debate.
Thanks everyone for your input....these forums really are an incredible resource. I guess it helps you commentators keep it all fresh in your mind. Cheers Kelsall
^^^ Please for the love of God (and our entertainment) put in an RCD socket and let the assessor pull you on it..... then ask him to give you the reg numbers that it goes against??????
Reply to Testing a socket in the middle of a distribution circuit. in the The Welcome Forum area at ElectriciansForums.net
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Hi everyone, On a job at the moment and trying to Work out cable size needed for property supply. Lots going on and struggle to work out...
