Discuss Testing RCBO at Light Switch in the ElectriciansForums.net News and Updates area at ElectriciansForums.net
The BEAMA RCD handbook does state in the section for testing by installer;
All tests must be performed with all loads disconnected using an
appropriate calibrated test instrument connected as close to the RCD as possible.
But thats not the same as testing on the RCD terminals.
Also I think some rcds / rcbos actually need short pieces of cable on the load side to get a reading.
That is a lot of faff when , As has been stated, you are testing the circuit to the accessory to check the functionality of the RCD part of the RCBO. Now a ramp test is different and would warrant disconnection.
Reply to Testing RCBO at Light Switch in the ElectriciansForums.net News and Updates area at ElectriciansForums.net
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
I own two flats with a small common lobby. Although operable from both flats, the common lobby light appears to be wired to flat A's circuit...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
