Guest viewing is limited
westward10
Staff member
Admin
Supporter
I rewired my loft three or four years ago fitting two twin 58w fluorescents. Been up and down getting Christmas stuff down, about the third time there was a pop from one of the fittings and it stopped working. Back up there today and a bigger pop from the other which took the breaker out now I have darkness, looked in both and no signs of damage or water ingress and whilst it may be a bit damp up there I never expected them both to go at virtually the same time.
I had this a few months ago, a little furry friend had made a railway line out of the FTE.
There is absolutely no evidence of damage and the cables are such they are never trod on the pops definitely came from the fittings.
unless you want to be working over the holidays
invest in one of these?
What's the temperatures like in the loft. I had some that blew once when starting up from very cold. Could of just been coincidence though
It is very cold in the winter and by the time the tube gases had stopped swirling and got to temperature I had done what I needed to do up there.
https://www.researchgate.net/figure...ration-employed-in-most-of-the_fig1_261095054
It may be that the electrolytic capacitors in the electronic ballast needed reforming after a long period without being energised. Over time the oxide layer which provides some necessary insulation in the aluminimum-electrolyte rolled sandwich becomes thinner and thence unable to withstand the operating potential difference between anode and cathode. See:
Electrolytic Capacitor | Types | Capacitor Guide - https://eepower.com/capacitor-guide/types/electrolytic-capacitor/#
Upon applying power then after a long period these capacitors, especially the smoothing capacitor act like a low resistance and a large current flows; IsquaredR - in a small space equals rapid heating and a pop.
As an example here are some instructions for an ABB electronic motor drives which have not been used for a while:
https://library.e.abb.com/public/79...892e4/Guide_for_capacitor_reforming_Rev_G.pdf
westward10
Staff member
Admin
Supporter
Northamptonshire
United Kingdom
Electrical Engineer (Qualified)
The dark loft.
westward10,
marconi,
