westward10
Staff member
Admin
Supporter
Jul 15, 2016
23,296
315,788
Northamptonshire
I rewired my loft three or four years ago fitting two twin 58w fluorescents. Been up and down getting Christmas stuff down, about the third time there was a pop from one of the fittings and it stopped working. Back up there today and a bigger pop from the other which took the breaker out now I have darkness, looked in both and no signs of damage or water ingress and whilst it may be a bit damp up there I never expected them both to go at virtually the same time.
Reactions: ruston
Have you rang a local spark to assist, what I'm on about, could you have walked on a cable and damage it, IR the cable and all will be revealed.any way
I'm off to the pub for more drink po.
I had this a few months ago, a little furry friend had made a railway line out of the FTE.
There is absolutely no evidence of damage and the cables are such they are never trod on the pops definitely came from the fittings.
The games afoot Watson.
unless you want to be working over the holidays
invest in one of these?
Reactions: loz2754
,,Only thing that's likely to go 'pop' in a old style switch start fluorescent fitting is the PF correction capacitor, assuming they have one fitted
No they are only four years old so electronic chokes.
Plenty of things to go pop in electronic ballasts. Bypass them and stick in LED tubes.
Could do but will just completely replace them.
Reactions: pc1966
Electronic ballasts absolute carp in my experience.
Reactions: Dave OCD and 123
Electro if ballast if it had that unique burnt odor
I'd get a couple of the 5' 'high output' LED battens, they give at least as much light if not more that the old twin flourescent - and instant 100% light.
It is exactly what I am going to do.
Or if there's room the six footers are only a few quid more ?
westward10
Staff member
Admin
Supporter
Northamptonshire
The dark loft.
westward10,
marconi,
