didn't you see the video? It's to prepare for all the future circuits for your battery banks and electric car charging points! (If you can afford it after spending all your money on the CU) Just feed the cable into the already made hole...
Except that they probably wouldn't come in from the back.
Well it's smaller than the steel knockout and makes it nice and easy to feed the cables into the back of the CU, so what's the point in making the cutout smaller and more fiddly ?
It's into a partition, nothing is going to be easy to get back entry into that CU.
Going with that logic, they may as well knock all of them out, that would make it a lot easier.
Totally irrelevant. And there is nothing in the Regs about making a CU 'airtight' , if anything that's counter productive as we're told to install in such a way to minimise the build up of heat or words to that effect.
The Future of Fuse boards...?
Dustydazzler,
Mike Johnson,
