I really can't see the point of cutting a cable entry hole that size in the back board.
Looks nice
It is a pre punched knock outI really can't see the point of cutting a cable entry hole that size in the back board.
didn't you see the video? It's to prepare for all the future circuits for your battery banks and electric car charging points! (If you can afford it after spending all your money on the CU) Just feed the cable into the already made hole...In the wooden partition.
Except that they probably wouldn't come in from the back.didn't you see the video? It's to prepare for all the future circuits for your battery banks and electric car charging points! (If you can afford it after spending all your money on the CU) Just feed the cable into the already made hole...
Well it's smaller than the steel knockout and makes it nice and easy to feed the cables into the back of the CU, so what's the point in making the cutout smaller and more fiddly ?In the wooden partition.
It's into a partition, nothing is going to be easy to get back entry into that CU.Well it's smaller than the steel knockout and makes it nice and easy to feed the cables into the back of the CU, so what's the point in making the cutout smaller and more fiddly ?
Exactly! The enclosure is not air tight, and heat inside will be fanned into flames by the chimney effect of the void. just like nominally non flammable insulation on the outside of high rise buildings.The large hole helps vent the flames into the wall void.
Going with that logic, they may as well knock all of them out, that would make it a lot easier.Well it's smaller than the steel knockout and makes it nice and easy to feed the cables into the back of the CU, so what's the point in making the cutout smaller and more fiddly ?
As far as is reasonably practicable, to contain any fire within the enclosure or cabinet and to minimise the escape of flames.Totally irrelevant. And there is nothing in the Regs about making a CU 'airtight' , if anything that's counter productive as we're told to install in such a way to minimise the build up of heat or words to that effect.
Intumescent foam, of course.Won't be long before everyone is filling a consumer unit with expanding foam![]()
