Search the forum,
Discuss Three phase supplying a domestic flat. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
F
Fred Faulkner
Hi guys,
i had a look at a building in the west end of london which is spilt into 10 flats this weekend to do some upgrading works to the landlord area.
i noticed that there was originally 6 flats and the landlord must of added an addition 4 flats on top. Called 10 9 8 7. ( obviously).
The issue is that there has been a 3 phase submain wired in swa from the ground floor ryefield board . Which is then terminated into a 3 phase board installed outside flat 10/9 . From this board they have wired the two flats using all three phases therefore giving a potential of 400v across the circuits installed into the flats!!
i.e
flat 10 1L1 - lighting
flat 10 1l2 - smoke alarms
flat 10 1l3 - sockets
flat 10 2L1 - cooker
flat 9 is the same i.e
3L1 lighting
3l2 smokes etc etc!
this senario is the same for flat 8 7 !
im sure this is hugely wrong!!!
Hi guys,
i.e
3L1 lighting
3l2 smokes etc etc!
nope nothing wrong with it, there just balancing the load.
any electrician can tell at a glance it will be a polyphase board so whats the problem?
there shouldnt be a potential for 400v unless they use different phases for the lighting for example.
for example? using way 1,4,7 etc for lighting then there is no chance of 400v if mr diyer has a go himself
Polyphase board meaning?
Its a 3phase TPN board. I disagree with you this isnt best practise for domestic installations.
there is potential for 400v if a diyer linked off the smoke alarm feed for lighting. There is potential for serious danger
then he's no business messing with things he does not understand. anyway he's just as likely to die from 240V as he is from 415V. just that 415V might be a tad quicker.
because i can. now. have a look on your regs book and find me a reg. that says it's wrong.
Hi guys,
i.e
3L1 lighting
3l2 smokes etc etc!
It's unusual, but not wrong
That amuses me when people say that. Just cause three phase is present it does not mean they will receive a 415V shock. They will get L1 or L2 or L3 to earth @ 240V. Someone would have to be an absolute moron to put themselves across two phases to receive 415V.
trouble is, a lot of users are absolute morons
The load balancing is cr@p. If there’s ten flats with say 5 sub-boards the balancing should be coordinated across all boards. Not difficult if you take the time to work through it logically.
As for the 400V on lighting, unless the light switches for flat 10 are in flat 9 where’s the problem? As long as each flat is a separate entity there is no problem.
Reply to Three phase supplying a domestic flat. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
Hello, I'm new to this forum, we are in the process of converting into 12 flats all electric, no gas incl. heating, showers etc. An electrician...
Hi all, I have a regular client who has asked for a battery back up system to be installed at their home. They live in a rural location on a...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
I went along this morning to quote for an EVCP install. I thought it was a domestic house but it was a B@B. It has a 3 phase supply. I always...
11K
