Discuss To RCD or not toRCD in the UK Electrical Forum area at ElectriciansForums.net
A
Adam Smith
Afternoon all,
I am pricing a job to install a 32a cooker circuit. Cable will be in trunking throughout entire run and will go through a cupboard between the hall and kitchen. Fed from a retrofit wylex MCB, Iso and outlet plate all surface mounted, no socket outlet on iso. Gas and Water bonding in place.
Will I need to put an RCD on this circuit? If so I was planning on running the feed from the board to a wylex RCD in a 2 way enclosure.
Adam
^^^ agreed also but on another point, if you're running a 6mm cable in for a cooker, make sure you've de-rated it properly for being enclosed in conduit/trunking!
Reply to To RCD or not toRCD in the UK Electrical Forum area at ElectriciansForums.net
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
An odd question granted but bear with me. I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I...
Came across a cooker circuit with 10mm and 40A rcbo. Last leg was 6mm. Isolator to outlet. I downgraded to rcbo to 32A to accommodate the 6mm...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
