uksparks
- Reaction score
- 1,228
How many times and how long do you wait between each application of the torque setting?
what do you mean?
Discuss Torque Screwdriver in the UK Electrical Forum area at ElectriciansForums.net
copper gives so i guarantee if you just tighten it to the proper value once it wont be tight enough
what do you mean?
I haven't had it recalibrated yet, but as I mentioned in my post, I'm aware I should. This one is not due yet, think the advised period is a year. Dare say someone will come up monthly torque driver calibration device. Sounds like a niche in the market!
As I bought I'll use it, don't know what other people do with their purchases. My assessor never checked the existence of my driver, as I posted
I think you should start planning your exit strategy, cos I can see it being implemented in some form, in the 18th. Hopefully, I'll be retired by then.
Worse than a standard screwdriver as people will think that it's tight when it's not!
Watch out, telectrix will think your on about a cocktail
I own the Whia torque screwdriver set. I like it for the ends etc, but I'll be honest, the problem with saying do it up to xNm is fine, but if you just apply the rule with no common sense, it snaps conductors, so you cannot do it up that tight.
on breakers yes, fine as they have a clamp as it were, but anything where the screw touches the conductor, you need to just use your head.
Thats very true, however how I use it on breakers is to do them all up to what I would deem to be a good tightness then run over them all with the torque screwdriver and usually they don't take much to click.
I don't remember saying that?
- What torque is your head set to :smiley2::smiley2:
Given how much use? these things work at such small torque values it doesn't take much for them to be way out of calibration, this then leads to the problem that regular calibration is needed with torque calibration testers being expensive to own and third party calibration costing £40 a time doing this on a regular basis is going to be prohibitive
You have a valid point, how long is a piece of string. Buy disposable torque screwdriver? Or just keep the thing to flash at me assessor?
So you have a screwdriver how would you prove you actually used it is asked
I haven't got to prove anything, they just asked me if I got one.
Again they can ask me to use one how do they prove I haven't how would I prove I have
A double bluff, that will confuse them
I did have a idea of installing some 2" screws in some hard wood at different torques all labelled up then this could be used to prove the settings on it say every month or so
Reply to Torque Screwdriver in the UK Electrical Forum area at ElectriciansForums.net
