lol.............. noooooooo here is the odd thing, if I flip the RCD switch a few times quickly to get the motor turning, it eventually does not trip, it seems its only the initial power surge that trips it, once the machine is running, there is no problems.
you may end up getting a real spark in this time.
or he could get unlucky and end up with one of us. LOL.
hang on. is this a normal RCD or is it a RCBO?
seems you didnt read the start, I clearly stated its only when I use motors, like my Vacuum cleaner. I also have some power tools in the garage, which trip it all the time, but flicking the RCD quickly to get the motor started, then its okay.
My washing machine does not trip the rcd maybe because the power surge is not very big, TV'S everything else does not trip it.
Ive had this with inductive loads before, switch a 2D light in the bathroom on (not on RCD) and the RCD trips, leaving the light working and the sockets not... one sparks even rewired a complete lighting circuit but still same fault. I desided to play with the inductive load and ended up doubling up the caps in the fitting the fault stoped in all casses, (3 times in 20 years) still at a loss to know why! the RCD had been changed the circuit rewired, the fitting changed, only a change in cap stopped the tripping?? still makes me think there is an outside influence??
an RCBO is a combined RCD and MCB. usually only the same width as a MCB, whereas a standard RCD is twice as wide as it's double pole.
Oi Al, How big is your vacuum cleaner...?
I still want to know why you think your socket is run from the lighting circuit? Isit fused down? Did the electrician that do the 'board change' do this?
You have had this nuisance tripping problem for over a year now?
Why not go another year, why randomly now do you want it fixed? - to annoy the forum with bull?
You can't expect anyone on this forum to believe that anyone (in their right mind) would have an electricial fault for a year and not do jack about it + have 3 electricians that don't know what they're doing in a row.
Come on put us out of our mysery and tell us the threads an early april-fool or something.
