Hi ,
Bypass it means the old consumer units. Main disconector and MCBs for each circuit.
No RCD protection.May be I was not so clear.
Nothing weird.
Thank you.
bertt.
That is defiantly once the best posts I've seen here. Scary but funny.
Thanks for the reports guys.
Bertt, please don't advise the removal of circuit protective devices...ever...it won't be tolerated again, these forums are in the general public domain and it's likely someone will get injured or killed.
To all. Don't quote a bad post, it makes life harder to moderate a thread if you do.
Thanks Tony this is true.
For clarification, if you've quoted a post that later gets moderated or removed then your post also needs manually editing by the mod to remove the quote. It can get time consuming and occasionally we might miss one of the quotes as well. It also means you'll get an automated PM saying one of your posts was edited even though it was just the offending quote that was removed. This is just the way the forum board works I'm afraid.
