Discuss trying to install sensor switch in the Lighting Forum area at ElectriciansForums.net
SO, I have this Lutron single pole switch and I realize it has a neutral wire and of course the switch Im replacing has only the Hot and the load wires SOOO---What do I have to do try and find a sensor switch with no neutral? Is that a thing?
What type of "sensor switch" are you wanting - occupancy sensor?
Lutron do make one - try Googling:
Lutron Maestro Motion Sensor switch, no neutral required, 250 Watts Single-Pole, MS-OPS2-WH
Reply to trying to install sensor switch in the Lighting Forum area at ElectriciansForums.net
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
I am swapping a light switch in France for a motion sensor with two simple connections. The switch I wish to remove has two black into one...
