Hello all here’s my first ever post.
Quick background, I’ve been working for myself since theturn of the year building a portfolio, I have done a few minor works and a weekon Monday I will start a house rewire and wiring extension which I plan to useto be assessed on.
I was asked from someone local to take a look atswapping a single socket to a double (on entrance to kitchen) and also toextend the cable out for three sockets in a boot room as the room was being drylined to hide pipes and the cable would not reach the sockets.
Simple enough, however when I arrived today I checked outthe CU which has combination of 3036 rewireables and a few plug in MCB’s. Asfor the earthing arrangement it’s a TT but no presence of RCD or VOELCB, gasbonding (added when boiler changed I think) but no water bonding, the main earthis 2.5mm not mechanically protected which feeds to an outside wall where it hasbeen joined using a terminal block before connecting up with a cement coveredrod.
So my initial thoughts were I would effectively only bereplacing like for like but I thought this really doesn’tlook good to me, could be a can of worms with a ring pull on top! I thought TT systems should have some form of RCD faultprotection - is that not correct
The client was not around until tomorrow so Ithought leave as was and will speak to them tomorrow to advise they requiremore urgent work doing.
