• Welcome to the new forum. We're now hosted on ElectriciansForums.net rather than ElectriciansForums.co.uk - Chat about the forum upgrade by CLICKING HERE
Welcome to our Electrical Forum - We started out providing electrical advice just for the UK - But now we have specific advice for the USA too! - Register for free and share American Electrical Advice.
Discuss Twin&earth and SWA installed loose on floor in the Electrical Forum area at ElectriciansForums.net
StigOfTheDump
EF Member
Hi All,
The contractor working for Magnet Kitchens at my brother's house has run the sockets ring in 2.5 T&E, plus an SWA for the cooker supply, by laying these cables on the floor under the units.
I'm fairly sure this isn't acceptable - at least these cables should be clipped up against the wall (shouldn't they?).
We had actually expected the cables to be chased into the wall before the units were fitted, but they've done the electricals and plumbing after the fitout...
Any thoughts or comments? Many thanks.
Pete999
Forum Mentor
Electrician's Arms
Trainee Access
Hi All,
Yeeha, why SWA how has he terminated the SWA at the CU and CCU?
Gavin John Hyde
Electrician's Arms
CCTV / Alarms
I have often run cables in flexi conduit under kitchen units, using saddles to keep it in place, it saves chasing the wall out for various bits. once the units are back its unlikely to get damaged. That being said that in your pic looks a bit rough, at very least it ought to be clipped to the wall or be put in some trunking. what will be going in the gap in your pic? washing machine?
StigOfTheDump
EF Member
SWA was used so they could cross the kitchen without digging up the floor - it goes out of the CU (suspect without an SWA gland), through the wall, around the outside of the property, through the wall and into an isolator inside the cupboard next to the cooker
Pete999
Forum Mentor
Electrician's Arms
Trainee Access
So nil glands? they have used T&E as well so again why SWA? the excuse they gave given is a poor excuse, have they provided any certificates for the electrical work? would love to see that, so it's very doubtful, from the information and pictures it looks like a real Cowboy Job, was the fitter's name Kevin or Buffalo Bill, cuz he sure as heck wasn't an electrician.
If as you say the contractor worked for a reputable Kitchen supplier, then this electrical butchery should be brought to their eattention, I would imagine (no proof of course) the kitchen outfit belong to one of the CPS schemes, NICEIC etc no idea which one, they need to be contacted as well, I had a new kitchen fitted some years back, and when I aske the fitter how he would do the electrics, he was going to crimp the joints and bury them in the wall, he got short shift from yours truly, and I did it myself, Wifey didn't want any trouble, so I left the complaining alone, a mistake on my part, take these Butchers to task, trading standards, check a trade or whatever one they belong to, get some payback, crikey what a bodge job, makes you wonder how many innocent house holders are conned by these charlatans.
StigOfTheDump
EF Member
The job hasn't been signed off or certified yet. Anyway, I'm advising that my brother shouldn't accept this work.
The contractor was going to do the external run in T&E until my brother (a civil engineer by profession) insisted that SWA be used.
StigOfTheDump
EF Member
I'm dubious about the rating of the SWA too. It is less than 15mm external diameter (outside the jacket around the armour). Is that likely to be the 6sqmm or 10sqmm conductors required for a cooker supply?
Midwest
Electrician's Arms
Its not pretty running cables loosely like that, but would you expect the cables to be run in the ceiling void if it was rewired.
I normally run the cables in trunking in that service void, but I do that before the floor units are fitted, so bit difficult in this case. That said, a bit of trunking across this unit, would tidy things up.
Midwest
Electrician's Arms
The cable conductor size etc, should be embossed on the sheathing.
Edit; swa has a higher ccc for an equivalent tw&e
telectrix
Scouser and Proud.
Respected Member
Forum Mentor
Electrician's Arms
CCTV / Alarms
Solar Guru
Trainee Access
debatable. the cables are supported by the floor. they are not where they are liable to sustain mechanical damage. maybe compliant, but not good practice.
edit: did not see the pic before. that is dog rough. get them back. as advised before, some trunking would tidy it up. and running the SWA outside is just a lazy way of not doing it properly.
Pete999
Forum Mentor
Electrician's Arms
Trainee Access
You need to ask the Kitchen company for an Electrical Installation certificate for the work done, post it on this forum for consultation.
Reactions: DPG
Gavin John Hyde
Electrician's Arms
CCTV / Alarms
I think he will struggle for one of them, at best he might get a dubious minor works certificate....
buzzlightyear
please let me back in to the prison cell.
Electrician's Arms
could have put it in trunking,
dam, beaten by Teletext.:D
Electrician Talk
Electrical 2 Go - Electrical Supplier and Electrical Wholesalers
Electrical Insurance
ElectriciansForums.net (formerly known as ElectriciansForums.co.uk) was setup in April 2006 to provide free electrical advice to both professional and DIY electricians. Whether seeking advice for auto electrics, trying to find electrical installation condition reports (EICR) form downloads, or whether you're here just to talk to other electricians; we've been a first-choice website for tens of thousands of sparkies for well over a decade.
