Both those manufacturers are acceptable. Easy to install, as long as you're careful about the area measurements and don't end up with heating mat left over as you can't cut it off and the overspill has to go somewhere. Make sure you don't lay any of the cable across itself - it'll burn out. How well does it work? Depends what's on top of it and underneath it. You need to insulate well below otherwise you'll be heating that instead of the room. Laminate or thin tiles are usually OK, but thick tiles kill it - you'll spend all your time and money trying to heat the tiles and the heat'll never get through.
Before you buy, call the maker and tell them what you want it for (primary heating fo the room, secondary, just to keep the feet warm) and get them to recommend the size and type of heat mat/wire.
PJ
