Discuss UPS supply problem in the UK Electrical Forum area at ElectriciansForums.net
Perci
Hi
Recently we were asked to put in an 80A 3 phase supply to a UPS system, we carried out the work to the manufacturers guidelines with an 80A mccb in the panel board. To much annoyance of all the office workers, when the supply was turned on it blew all 3 of the main fuses that are rated at 100A.
Has anyone had any similar problems?
Single phase links left in?!!
What other loads are connected? An additional 80 amp load connected might be too much for the 100A supply, but I wouldn't expect the fuses to blow instantly, unless the supply was already overloaded.
Do you mean inside the the actual ups box? We didn't install that part so that could be! Wouldn't you expect the 80A mccb to trip first with that kind of fault conditions?
That was my first go to that they were overloading their supply but with load tests they are pulling 40A per phase so it's not too bad
I'm not intierly sure to be honest when I get back to the office tomorrow I'll find out. There is 10 seperate ups backups but we were just given a 5c 10mm flex that needed a supply.
If there are 10 separate modules in the UPs it more than likely not an AP Emerson type as they usually come in 7.5 10, 15 KW etc
Yea I'm not to sure on the specs of the ups I just no it's quite a large set up. It's is used to keep the mainframe computer racks going during power failure such as what happened when we turned it on
That is at the same place as this ups. It's one of the most rediculous things 20 twin sockets per length and there is 3 of them in the same room!
Hi
as the load will be highly inductive, then the load will be very re-active.
Sort of like a start up surge on an electric motor.
You might need to use breakers with a time lagg
such breakers are used on electric motors and
are designed to cope with a large but short start surge.
the term used in Australia is "slow-blow'.
Reply to UPS supply problem in the UK Electrical Forum area at ElectriciansForums.net
We are looking for a distribution board to provide 3 * 160A three-phase feeds, but they are basically redundant supply path options so max total...
We are refurbishing an empty commercial building at the minute and I don't do commercial stuff day in day out so not entirely clued up on...
Hi I have UPS 50KVA and the inverter output AC voltage is feeding a distribution panel 120/208 V 4 wires when I check UPS display it shows me...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Had UKPN come out to a property recently to upgrade the main fuse from 60A to 100A but when they arrived they said that the supply cable which he...
