Discuss URGENT 2394 in 2 hours time!!!!! in the UK Electrical Forum area at ElectriciansForums.net
Hi I've got my 2394 in a couple of hours and a practise question was write a list of consumer units and protective devices cheapest to most expensive good and bad points for each. Plus if anyone knows of random stuff they might ask cheers
Who concocted this crap? It has nothing to do with any inspection and test procedure.
It has no relevance whatsoever to BS7671. The only option for CU's and switchgear, is that meets the required British Standard in the case of MCB's RCD's RCBO's etc it is BS60898, BS61009, BS61008 and so on, cant remember what BS no's apply to CU's there are a few. As long as the kit is compliant, price has no bearing on the issue whatsoever.
Tell whoever set this question, to do something more relevant to the subject, like asking things like "Where an RCD is used for additional protection on a new ring final circuit, it should operate in how many ms at how many times its trip current, and how many mA".
Cheers...........Howard
Are they asking, re-wirable fuses, cartridge fuses, MCBs, RCBOs. Split CUs, high integrity CUs, never understood why they are called high integrity though, with the pros and cons of each?
They shouldnt be asking random stuff, City and Guilds wont!. Your course, exams, and practical assessments should only contain relevant info from GN3, GS38, OSG and BGB. Anything else is totally irrelevant to the qualification. GN3 contains all the relevant bits from the other books, so you only need to learn one publication, but need to be aware that it is connected to the others. If you know and understand GN3, you will have no problems.
Cheers........Howard
if you dont know the subject by now.............
speaking of which , i have my design exam in 24 hrs and dont plan on doing any revision tonite or tomorrow.
i either know it by now or not.
Absolutely!
Best thing I find before an exam is to just chill out, forget about the subject and finally stroll in there like a calm thing on a calm day.
Oh yeah, hope it goes well for you!
thanks guys.
time , or lack of , will be the killer for the 2396 written.
meh , pass or fail , i know i've put the hours in so we'll see how it goes on the day , i am fairly pragmatic towards exams. :)
just got back from sitting it myself, funny how the simple things just escape you on the night which five things did you list? we have been revising old 2391 papers and i found the questions tonight to be completely different in there wording which does throw you off very tight on time to
Polarity, earth sleeving, live conductors insulated, correct colours, connections mechanically sound but in gn3 it's different so maybe not as good as I thought. You?
no visual damage to insulation,no burrs or sharp edges on cable entries, metal back boxes earth, correct connection of conductors,can't remember the last one
just about didn't even touch on it in the course just from memory. i put 150mm from floors, ceilings and corners, straight lines vertically or horizontally between accessories? can't bring myself to check in the on-site guide tonight
- - - Updated - - -
- - - Updated - - -
dont think its from floors..
- - - Updated - - -
did mine today when do results come out ?
Reply to URGENT 2394 in 2 hours time!!!!! in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
5K
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
