W
Werner
Hi all,
Total diy beginner regarding electrical work.
I was hoping someone could give some advice regarding a thermal switch for a vmc (designed for heat circulation from a chimney) but id like to use this system with a radiator heater.
The problem is that the thermostat is set at high temperature 90'c and i cannot obtain this temperture with the radiator heater.
Is there a way to change the themostat to one that turns on at 30-40'c without to much issue?
Any advice would be greatly appreciated.
Thanks in advance.
