drzsta
hi all,
I have a situation where I would need to supply a 40kW installation from a Generator situated 300 meters away (not ideal). As this is a private LV supply up to 8% VD is permissible as per App. 4 Sect 6.4 in the BYB. However it then goes on to state that final circuits should not exceed public LV supply values of 5%.
The way I am interpreting this is that I can have up to 8% on my distribution cable to the origin of the installation(the DB) then a further 5% for final circuits.
This would lead to a possible situation of 348V L-L at the furthermost point in the installation if it did not contain lighting ccts.
Is this how others interpret it with respect to Section 525?
cheers,
drzsta
out in the cold
United Kingdom
Other
Volt drop..................................................
drzsta,
drzsta,
