Discuss Voltage between Neutral and Earth in the UK Electrical Forum area at ElectriciansForums.net
Sb8389
Hi guys,
came across a fault yesterday on a job where I was getting 15v between neutral and Earth at two sockets on a ring main.if u need anymore details let me know.
i am unsure what would cause this and want your expert opinion as I have never come across this problem.
the installation is an old 3036 board no RCD
TNS system
your replies are appreciated
it could be a phantom voltage. try with an analogue meter. if it's still there, check all earthing and bonding and the cpc connections on the socket circuit.
Hi guys,
TNS system
What was the voltage between neutral and earth, measured at the terminals in the board?
Reply to Voltage between Neutral and Earth in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hi was recently at a property and was installing a Solar PV system. was doing my testing and i came across a weird result when doing the...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
