- Reaction score
- 6
Hi folks,
I'm not an electrician and don't intend to do anything above and beyond the standard DIY changing of sockets/lights etc but I have a question that I'm interested in learning more about.
I recently came across the Wago connectors (which look to be a lot easier to use than the standard screwed connectors) but I was a little confused by which ones to use for which applications.
I was looking at the Wago 221 series (Wago 5-Way Lever Connector 221 Series 32A Pack of 25 - http://www.NoLinkingToThis/p/wago-5-way-lever-connector-221-series-32a-pack-of-25/5201r), which are 32A, and I'm guessing because they're 32A I would use these on a socket ring circuit (as this tends to be 30A, yes?). And then if it was a lighting ring circuit (as this tends to be 20A, yes?) I would use a 24A connector such as this: Wago 4-Way Push-Wire Connectors 24A Pack of 100 - http://www.NoLinkingToThis/p/wago-4-way-push-wire-connectors-24a-pack-of-100/9014r
Firstly, am I correct? Secondly, what would happen if you used a 32A connector on a lighting circuit? I can guess if I used 24A connector on a socket ring circuit it would blow but what about the other way around? Is there a danger to that too? Am I right that a lightning circuit uses 2.5mm cable (which is 2oA) and socket circuit uses 4mm cable (which is 30A).
Also, any Wago experts out there? I'm slightly confused between all the different series... for example series 773 doesn't seem to have an amp rating: 2-Way Push-Wire Connector 773 Series Pack of 100 - http://www.NoLinkingToThis/p/2-way-push-wire-connector-773-series-pack-of-100/77102 so what would these be used for? And what about these? http://www.NoLinkingToThis/p/5-way-lever-connector-222-series-pack-of-40/38224
Thanks all... just curious and wanted to know more.
