Discuss WANTED: Meter Calibration NE in the UK Electrical Forum area at ElectriciansForums.net
Also, do people use calcards on a regular basis to log readings? If so, how do you record these readings? Anyone got a blank spreadsheet they can share with me?
Calcard have a sheet you can record your readings on mate and think I got my sheet of this forum not got access to my Laptop with it on at minute mate sorry or you can use a socket that's not protected by RCD
Oh and I used Testermans for the calibration of my nagger normally about £40 ish they collect and deliver
Best place to get meter calibrated NE (Durham/Newcastle) - any thoughts? It's Metrel if that makes any difference.
HT can't your preferred Wholesaler help? I know the ones local to me offer Cal services.
EDS : 54 Silver Lonnen, Newcastle upon Tyne, Tyne And Wear NE5 2HD
Used to have a calibration day, some frown on wholesaler calibration , but if you are happy with it ,give them a try. :)
Cracking wholesaler by the way.
Reply to WANTED: Meter Calibration NE in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
HI folks,, Im registered as a DIY guy..I dont do much electrical around my building except the occasional replacement of receptacles, switches...
Hi all I don't appear to be able to post in the DIY forum so apologies if this is the wrong place. I live in a block of flats with an external...
