We've had a new kitchen installation and a new 9000watt induction hob fitted. The manufacturers recommendation is a 40 amp power supply, however the electrician (contracted through the kitchen supplier) had incorrectly fit a 32 amp fuse at the board. He knows this is the case , as does the retailer. (He calimed he assumed it was a 7500 watt hob despite the power draw being clearly visible on the appliance. Mistakes do happen though, I get it) We had new 6mm wiring installed and the hob is on its own circuit, its also less than 2 meters from the fuse board. . We are being told the hob is perfectly safe to use despite buying it to use at capacity, as a four ring hob wasn't meeting our needs. They have suggested sending an electrician to swap out the fuse for a 40, however do not want to replace the hob despite the fact installing it on the incorrect power supply voids any warranty. It's also worth noting the electrician knew he'd put a 32 amp fuse at the board and still submitted test sheets claiming its on 40. We have refused to allow them to simply swap the fuse until they agree a resolution we are satisfied with in writing. We have asked for an inspector to check the work, as its left us feeling uneasy. I'm looking for any independent advice I can before I just blindly allow a simple swap as if it's a non issue. I feel we are being dismissed, and the situation being downplayed, but I've read there absolutely can be bigger problems than just a tripped switch at the board. Granted I'm not an electrician hence my asking for any advice I can get. Can anyone give me a better understanding of the risks please? as I simply can't take them at their word it is 100% safe to use.
Thank you in advance for any and all assistance
