- Apr 30, 2025
- 2
- 0
- 1
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
I currently have a single electric oven and gas hob both of which are connected to a 32 amp (via a red switch isolating switch) fuse. I would like to remove the gas hob and install an induction hob with a power requirement of 7.4 kw. My question is will the 32 amp fuse be sufficient?
Thanks for any help.
