Discuss What did I do wrong when installing this single pole smart switch? in the DIY Electrical Advice area at ElectriciansForums.net
I replaced a single pole to exterior lights with a smart switch. Next to it is a 3way to my foyer light. The foyer and the smart switch to exterior works. However I seem to have killed the power to an exterior outlet. In order to get the switch to work, I had connect the red switch pigtail to a black wire I assume was the load? But then I had to connect the black switch pigtail to a cluster that included a red line (note I realize there may be an unnecessary extra pigtail in there that I have since removed). Any advice on how to get power back to the outlet receptacle? 20230609_155817.jpg
I replaced a single pole to exterior lights with a smart switch. Next to it is a 3way to my foyer light. The foyer and the smart switch to exterior works. However I seem to have killed the power to an exterior outlet. In order to get the switch to work, I had connect the red switch pigtail to a black wire I assume was the load? But then I had to connect the black switch pigtail to a cluster that included a red line (note I realize there may be an unnecessary extra pigtail in there that I have since removed). Any advice on how to get power back to the outlet receptacle? View attachment 108625
Sorry for the long delay but the biggest problem I see is the neutrals or white wires are hooked to the single pole switch. You sound only have 2 wires terminated to the switch and an equipment ground. I’m guessing that one of the white wires was being used for power to actually turn the light on. It should have been taped with black or red to identify its purpose.
Reply to What did I do wrong when installing this single pole smart switch? in the DIY Electrical Advice area at ElectriciansForums.net
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi, I am installing a new bathroom fan. We had an electrician who ran 14/3 into a junction box. The black feeds a led light and the red was...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
Hi everyone. I bought one of those smart switches, specifically the Kasa 3 way kit (HS210 KIT). But when I opened my 3 way dumb switches I see...
DYI guy here with some basic knowledge of electrical craft. I am helping a buddy in his remodeled bathroom. His GFCI outlet was powered off vanity...
