OP
deancooling
There is flex connected. 1.5mm. Cu is rcd protected. Appreciate the help
Discuss What other types of cables can be chased into walls? in the UK Electrical Forum area at ElectriciansForums.net
Actually this is a very good question. Reason I have wired a couple that had 2 16 amp supplys, one for the blowers and one for the heater. To be fair though they were considered large, the average whirlpool is 4 kw, also agree with hawkmoon and trev about ignoring the plumber and getting proper advice.Is the flex just suppling the pump for the blowers I take it there isn't a heater fitted as well.
Can you see why I gave you a bit of a bashing in the last thread now Dean when you were talking about a 10mm2 cable? good luck fella I am done here now, just be careful.The flex is connected to an ip rated box which has some components inside. this is where the supply is connected too. Board has 2 rcds covering 4 circuits each.
Reply to What other types of cables can be chased into walls? in the UK Electrical Forum area at ElectriciansForums.net
