Cable routing questions | on ElectriciansForums
Discuss Cable routing questions in the UK Electrical Forum area at ElectriciansForums.net
firestick
Ireland
Hi,
I have two questions about domestic wiring In Ireland
1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage wall (where the consumer unit is located) to under a suspended timber floor on the other side?
2. Should cables running under a suspended timber floor be secured to joists or is normal to have cables resting on the ground?
Thanks!
Good question & quite a few options here.
Item 1 Would be No conduit required
Item 2 We’ve all seen cabling lying on the floor, not ideal but if they are installed in a groomed manner, & supported when rising from the floor it can be presumed ok.
Obviously the area must be free from debris & rodents.
If access is possible why not All Band cabling to the bottom of the joists/fixings
thanks!
You're familiar with Irish wiring regulations?
Reply to Cable routing questions in the UK Electrical Forum area at ElectriciansForums.net
Hi All I would appreciate some help with a few questions here regarding cables sizing, I'm using the latest 18th edition, amendment 2. Q1...
Because those walls are crumbly lath and plaster.
Sorry, 3. Should read: separate circuit from consumer unit with 16amp radial supply only to this lighting/camera…
