firestick
Hi,
I have two questions about domestic wiring In Ireland
1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage wall (where the consumer unit is located) to under a suspended timber floor on the other side?
2. Should cables running under a suspended timber floor be secured to joists or is normal to have cables resting on the ground?
Thanks!
Thanks!
