deancooling
Wanted to use a switched fcu outside the bathroom in t&e but then maybe some flex from that going into the bathroom under the bath for a whirlpool ?
Discuss What other types of cables can be chased into walls? in the UK Electrical Forum area at ElectriciansForums.net
no he isn'tflex outlet plate is the way to go...
You electrician?
You electrician?
So it's a wind up then. Best call a mod, I'll give Andy a shoutRead his previous posts - and he seems to have moved from Sussex to Scotland!
I was thinking the same thing, hopefully the OP will return and confirm either way so we can help him avoid electocution, Must be careful what is said here as the team are waiting to pounce and ban any unfriendly remarks. I hope the OP understands we want to help not take the pees.Murdoch - see what you mean on the previous posts...
...he's obviously decided to scrap the 10mm t+e in favour of a bit of flex!
Reply to What other types of cables can be chased into walls? in the UK Electrical Forum area at ElectriciansForums.net
