deancooling
Wanted to use a switched fcu outside the bathroom in t&e but then maybe some flex from that going into the bathroom under the bath for a whirlpool ?
Discuss What other types of cables can be chased into walls? in the UK Electrical Forum area at ElectriciansForums.net
no he isn'tflex outlet plate is the way to go...
You electrician?
You electrician?
So it's a wind up then. Best call a mod, I'll give Andy a shoutRead his previous posts - and he seems to have moved from Sussex to Scotland!
I was thinking the same thing, hopefully the OP will return and confirm either way so we can help him avoid electocution, Must be careful what is said here as the team are waiting to pounce and ban any unfriendly remarks. I hope the OP understands we want to help not take the pees.Murdoch - see what you mean on the previous posts...
...he's obviously decided to scrap the 10mm t+e in favour of a bit of flex!
I genuinely am worried about the op and I mean it. He was going to put a 10mm2 cable into a joint box under the bath to feed the bath and the shower. He then said the shower would be a seperate run and it was 9.5kw, so we were okay with that and hopeful it was okay. Then the whirlpool bit got all confused and over the place, looks like a flex from a 13 amp spur is going in now. The last time we chatted he couldn't confirm the load of the whirlpool, hopefully he knows what it is now and will let us know.If you really want to come over as friendly I suggest you put the finger away lol
I may be a stickler for manners (i'm a bit old school) but if I had posted a question requesting advice on a forum I would NOT wait an hour at least before bothering to respond to posts
Well said.
The ones that really pxss me off are those who post questions, never say thanks, never give feedback and then start a new thread.
Hear Hear if the OP can't be bothered why should illustrious Forum bother with him/her bad manners, I agree it ticks me off as well, the question is, if this is a peestake then FFS why, I have better things to do than answer ridiculous questions, only to find its a wind up, I'm going back to the bottleWell said.
Found out whirlpool is sufficient on a 13a spur by plumber. So i was thinking seperate circuit, 2.5mm t&e switched fcu outside bathroom to isolate. But still unsure on what to run from the fcu to under the bath? Some sort of flex cable ? Bath comes with a ip rated box under it for connecting too. THANKSI know, it's like they are doing you a favour! lol
Reply to What other types of cables can be chased into walls? in the UK Electrical Forum area at ElectriciansForums.net
