Discuss What training course I will need to do my job safely? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
L
LordKelvin
Dear All,
Someone will remember me from the other 3D...I am still in training (so not going in the field) but my tasks are taking form and I would ask to you experts what kind of training course I will need to attempt to be SAFE myself and...safe the others...
The machine has got mechanical (rotating parts, blades to cut, etc..) and of course electrical components (switches, relays, motors, PLC, circuit breakers, etc.)
My tasks might be:
1 - troubleshooting of ANY problem in our machines sold to the customer. So I will know the machine and all its components.
2 - design improvement of the machine (mechanical side and electrical side)
my doubt is: I have a degree in Mechanical Engineering, Do I need to be an electrician for this job?? I do not believe so because it`s less challenging than be sent somewhere to fix some machines...it`s OUR machine and we know where it will be sold...
At the same time I suppose I will need some "official" training on safety etc.
May you guys please advise me about what I need exactly to do this job on the electrical side? there are 1 day course, 3 days courses... 17th courses... I am a bit confused :(
Really thanks.
Mario
Your training should mainly be in relation to machinery controls and machinery safety and how to design and modify these in safe manner.
You should know electrically what constitutes a safe supply for your machines but thereafter the Wiring regulations will be fairly irrelevant.
You should also be trained in the relevant regulations applicable to the provision and use of work equipment (PUWER), Supply of machinery safety regulations, health and safety at work act, etc.
You would also need to be aware of the applicable standards like these, if relevant to your machines (taken from the Schneider handbook)
EN ISO 12100 Safety of machinery - General principles for design - Risk assessment and risk reduction
EN 574 Safety of machinery - Two-hand control devices - Functional aspects - principles for design
EN ISO 13850 Safety of machinery - Emergency stop - Principles for design
EN 62061 Safety of machinery - Functional safety of safety-related electrical, electronic and programmable electronic control systems
EN ISO 13849-1 Safety of machinery - Safety-related parts of control systems - Part 1: general principles for design
EN 349 Safety of machinery - Minimum gaps to avoid crushing of parts of the human body
EN ISO 13857 Safety of machinery - Safety distances to prevent hazard zones being reached by upper and lower limbs
EN 60204-1 Safety of machinery - Electrical equipment of machines - Part 1: general requirements
EN ISO 13855 Safety of machinery - Positioning of safeguards in respect of approach speeds of parts of the human body
EN 1088 Safety of machinery - Interlocking devices associated with guards - Principles for design and selection
EN 61496-1 Safety of machinery - Electro-sensitive protective equipment. Part 1: General requirements and tests
EN 60947-5-5 Low-voltage switchgear and control gear - Part 5-5: Control circuit devices and switching elements - Electrical emergency stop device with mechanical latching function
EN 842 Visual danger signals - General requirements, design and testing
EN 1037 Prevention of unexpected start-up
EN 953 General requirements for the design and construction of fixed and movable guards
EN 201 Plastics and rubber machines - Injection moulding machines - Safety requirements
EN 692 Machine Tools - Mechanical presses - Safety
EN 693 Machine Tools - Safety - Hydraulic presses
EN 289 Plastics and rubber machines – Presses - Safety requirements
EN 422 Plastics and rubber machines - Blow moulding machines - Safety requirements
EN ISO 10218-1 Robots and robotic devices - Safety requirements for industrial robots - Part 1: Robots
EN 415-3 Safety of packaging machines - Part 3: Form, fill and seal machines
EN 619 Continuous handling equipment and systems - Safety and EMC requirements for equipment for mechanical handling of unit loads
EN 620 Continuous handling equipment and systems - Safety and EMC requirements for fixed belt conveyors for bulk materials
Richard,
Really thanks for your very long reply!
So for all the listed standards I could actually and literally take a book and study? Like the Schneider installation book and machinery safety handbook right?
Re the first part of your post I wonder if I could have more detail I mean lot of course are called safety of machinery other electrical safety...some are 1 day and might be mostly theoretic..others 3 days like workshop but I dont know if I need to become almost an electrician due that I will troubleshoot something that might be faulty on the electrical side :(
If you are only working with machines made by your company then you should not need to know more than the basic electrical comprehension of the supply to the machines (which is what would come under BS7671), however for the electrical controls and interlocks within the machine then you would need to know the details of BSEN60204 to cover the electrical equipment of machines.
This would be different from the requirements of the wiring regulations (BS7671) which is what one would generally expect an electrician to know
However it would not stop there because you would also need to know about emergency stops and safe design of safety circuits, etc.
You would need to know electrical theory in a basic manner to understand current flow and resistance and switching etc..
The greater part of your need would be how your machines operate and and can be repaired (within the requirements of the standards)
Probably your best bet would be to contact the suppliers of the electrical controls used in your machines and see if they run training courses in the appropriate topics for your needs.
Most of the safety components are from Schneider. I could consider myself lucky...I already downloaded the handbook (64pp) and the installation guide (almost 500!).
So my needs are not to become "almost an electrician" then. But what if they call me and say the machine stopped and the fault is in a safety circuit or on the electrical side of it? I will not need perhaps to know how to find a fault and also work live?? This is not being "almost" an electrician? Or you guys think my job will be quite easy on the electrical side because I know in detail the machine and I will just need basic safety rules and thats it?
The standard definition of an electrician is someone who works to BS7671.
You would not be a standard electrician, the majority of BS7671 will not help fix a machine.
If a machine is not working then you can initially test to see if there is power going to the machine if there is no power then you ask the customer to arrange repair of the supply, this would not be down to you. Though you may well need to know the type of supply, current, voltage, inrush current, vibration resistance, type of cabling required for the machine but this would be standard specifications for that machine.
You would need to know how electrical systems (inside a machine) work in detail.
You will need to be able to diagnose a fault on the electrical controls, wiring, control systems, safety systems, etc.
In general you would not work live as this is against the Electricity at work regulations 1989.
The skills in fault finding are learnt over time and cannot be easily taught because each situation is different, however as you will be working on specific machines you should be able to garner information about the most common faults easily.
give schneider a ring (telford, or call the one in ashby and ask to speak to phill at the training school), they have there own inhouse training now.
they offer the basic electrical safety you will want and courses on there kit there in the workshop.
bassically part theory and part practical on giant breadboards.
if it is just emergency stops are they simply wired through a contactor that will drop the power out on activation or do they send a low voltage control signal. these are all things to consider.
Guys will it be enough a 1 day training on safety from an electrical training company (Tinson training)??? I do not underdstand if it is enough just 1 day course or I will need a more comprehensive one...
I can also read the books on my own of course....
Reply to What training course I will need to do my job safely? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hello all Well, been putting it off, but I need to upgrade my 17th edition to the 18th. Not been a practising sparky for over 5 years, but I have...
Hi, Just wondered if anyone knows whether there is such a thing as a distance learning version of the level 3 (C&G or EAL) Electrical...
4K
So I recently completed a 4 year apprenticeship, EAL Level 3 Diploma in Advanced Manufacturing Engineering and HNC in Electronic and Electrical...
I am writing to express my strong interest in joining your esteemed organization as I embark on the next phase of my career in the field of...
Electrical Courses
