Discuss Whats causing a voltage increase on a water pump? in the Commercial Electrical Advice area at ElectriciansForums.net
Hello.
I'm doing a favour for a farm friend, they have a water pump down a bore hole thats been slowing down recently.
The single phase 0.55KW motor is situated 40m down the well and the controls are at the distribution boards.
The voltage going to the single phase motor is reading L-E 247 & L-N 314.
The farmers wired it all himself with all red coloured singles and has a hand made drawing of his overload and starter controls.
What could be causing the increased voltage ?
If his supply is single-phase the problem is 99.9% with the DNO. If his supply is 3-phase or split-phase the problem could be anywhere upstrem of a 3-phase or split-phase DB. Other stuff could be getting fried so needs isolating and sorting. If the pump is getting 314V but running slow, it's probably already wrecked.
Reply to Whats causing a voltage increase on a water pump? in the Commercial Electrical Advice area at ElectriciansForums.net
Hi everyone, I need some help with an electrical issue I'm experiencing. I recently created a new circuit for an electric oven at my friend's...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
Need some help please. Got a brain teaser for my first post. My pool pump motor cratered over 4th of July. It was working fine and started to...
I have a submersed bore pump 85M down and covered by 40M water. The motor/pump is 1.1HP, capacitor run, 35uF in a capacitor box above ground, with...
