What's the consensus on this then? I'd be interested to gauge the opinions of everyone here as to what's preferable.
Got a ceiling rose with 4 cables coming into it from above a plasterboard ceiling in an insulated, boarded out loft. Would you have:
Scenario A) These cables run along the plasterboard ceiling underneath insulation, then straight down through the hole in the ceiling, to the rose fitting.
Scenario B) they lay on top of the insulation before piercing through the middle of it and then down through the hole.
Obviously scenario A is a recognised reference method. But the regs also state that where practicable cables should not be covered by the itchy stuff. So let's say they're laid on top of the insulation - you're then trapping them in with the loft boarding, so it effectively becomes a stud wall.
Be interesting to hear some thoughts on this, as you could make the case for either.
The chances on either method having a negative effect is probably non existent.
I find it preferable to be above and clipped where it can be rather than run across the insulation.
Many times I've lifted insulation to find rodent damage.
Fair. Just wanted to gauge opinion as if the loft isn't boarded the answer becomes a lot simpler.
Yeah in an ideal world you'd have good access and clip it to the joists when installing - before all the boarding goes down!
