Discuss Whats the best LED GU10 dim bulbs you use ? in the Lighting Forum area at ElectriciansForums.net
LukeD
Going to think about stepping away from Lucceco . But not wanting to pay fortunes . What bulbs do you have good results with when matching with the right dimmer modules etc ? thanks
Philips Master Expert Colour with Varilight dimmer. Despite the claims, the lamps are more like a 35W replacement than 50W though.
I have been using the LAP non dimmable lamps for a couple of years now with no failures.
I've not tried the dimmable ones though.
I also recommend Varilight dimmers, I've not come across a situation where they didn't work.
Just to point out that the lamps linked to by @marconi are not actually the dimmable ones, which can be found on the website elsewhere.
i use the lap dimmable with varilight pro, installed hundreds and not been called back to one yet. also they have a 3 year warranty which i point out to the customer so they would call me back if they were faulty.
V pro it is then !
Maybe I just need to really concentrate when setting them up ! sometimes they fly straight from the bag. Other time I am doing morse code for 10 mins !
I now write with a permanent marker the date on a new LED lamp when it is fitted - because they don't seem to last that long - two years at most. SAXBY do a replacement service IIRC should the lamp fail within its warranty period - check this though:
https://www.saxbylighting.com/docs/...y_lighting_warranties-14-02-2020.pdf?sfvrsn=2
I have never used it TBH - life is too short sometimes to go through the faff.
Again, Varilight V-Pro and either LAP dimmable GU10's, or Aurora Ice dimmable GU10s (if the client wants to spend a bit more, they kick out a bit more light per watt).
Incidentally, for the V-Pro modules, it works out cheapest to buy a 2-gang dimmer from screwfix (code 98455) and just take the modules out.
I think this is the first time I have read a positive review about LAP products on this forum. So positive that I shall in fact give them a go. One question about the Vpro. What's the minimum wattage led, s it will satisfactorily dim?
Have a read through the instructions. It's got all sorts of adjustable parameters:
True !! . I also use to use Hamiltons .Expensive and super reliable. But not easy to get
While we are on the subject of led lamps, occasionally I come across situations where customers complain of a very slight flicker from their leds .On investigation I have not always been able to nail down the issue and end up suggesting we try a better quality lamp, which often does the trick. However it is frustrating when you don, t find out the exact cause of the issue. I wondered what you guys find to be the most common cause, s of led "flicker" and what are the most common solutions?
Reply to Whats the best LED GU10 dim bulbs you use ? in the Lighting Forum area at ElectriciansForums.net
