Resu
Mentor
...in the centre at the bottom. Had a squizz on Google but can't seem to find them.
Not sure of name, but if think it's the De-Icing model, charcoal colour :)
Ugly, was it the connector on top of the igniter that's started all this?
looks like its hinged like a scotch lock.
It's one piece. It looks like that from the heat, it's started to melt.
Just had a thought, the tower was made in Italy so it's likely a European connector. Like a connector block but rather than a screw coming down it pulls a clamp up similar to a terminal on a PCB. Will replace it with a couple of Wagos but thought it might be handy to have a couple of these in the van for bigger cables.
They're made by Cembre.
http://www.cembre.com/family/details/3943
They're really useful for junction boxes (connecting SWA cores to T&E for example) and much better than choc block. I now mostly use Wagos for the small sizes, but the bigger sizes are still useful. The connector will accommodate two wires of the nominal size or any combination of wires up to the same total csa.
RS used to stock these in sizes from 2.5mm² to 35mm² (I think).
http://uk.rs-online.com/web/p/connection-termination-blocks/3156308/
RS have now changed over to an inferior connector for most of the sizes.
| RS Pro Non-Fused Terminal Block, 1 Way/Pole, Screw Terminals, 2.5 mm² Panel Mount, PC, 450 V | - http://uk.rs-online.com/web/p/non-fused-terminal-blocks/8680809/
I've been trying to find an easy source of supply, but only found this.
Cembre terminal blocks - - http://www.lst.fi/webshop/en/store?page=shop.browse&category_id=1421
Junction box
Temporary repair
| 1 Way Connection & Termination Block, Screw Down, 450 V, Clear | - http://uk.rs-online.com/web/p/connection-termination-blocks/3156308/
Junction box
Temporary repair
You sir, are a legend! Have bookmarked for future developments.
Resu,
Lucien Nunes,
