Discuss Where to put sockets? in the UK Electrical Forum area at ElectriciansForums.net
Have you put the worktops in yet? How much space have you in the kitchen?
I use 700mm or wider over washing machines etc. OK, it's more expensive, but it makes life a lot easier.
If that is too expensive, space the units and worktops out by 100mm or more and construct an upstand with facing to match the worktop, leaving tons of space for cabling etc.
The kitchen is narrow but long - galley kitchen. At the design stage, have the plans drawn and now looking at findins out as many issues before we start the actual work.
Standard worktops so 630mm deep I believe.
As Tel and I have both said, use a wider than standard worktop. 600mm are fine for integrated appliances.
630 or 635 are used, for example, by Ikea, as their "standard" size. 700 and wider are readily available.
Building out a "standard" size with a "dashboard" at the back gives you tons of service space and can take socket outlets etc if designed correctly, and gives a raised ledge for your spice bottles and ashtray...the top or lid can be retained with magnetic catches...it's the way forward!
Grid switches for appliances, are typically used in new builds, to comply with Part M building regs. In your existing property, you do not have to.
However, some people like the idea of having appliance isolating switches in one place, as opposed scattered around the kitchen. That said, a socket mounted in a floor unit, is perfectly acceptable. Its your kitchen, choose the install you want.
Get DP switched socket outlets.
Am I missing something but I've never had an issue with an outlet in the wall behind an appliance. Domestic appliances are designed to facilitate this?
You lucky then.
Washing machines, dishwashers and fridges will not push right back if the is a plug behind.
I always fit a surface patterns with unswitched socket in an adjacent cupboard to the appliance controlled by a FSU or double pole isolator above work bench.
I’m not telling you, go find out for yourself ;-)
I have never fitted one . I have been to a few that have caused problems though.
I am in the camp of the isolator above the appliance , as in white goods , and accessible for all others. Not all customers will have them above , so it is where practical
In spite of what GeorgeCooke (Winston) writes, isolators are the norm and practically everyone will fit them. Be thankful you're not in the south of Ireland where they are mandatory within two metres of every appliance - ruling out grid switches.
My name is not Winston. Isolators are not the norm except for cookers and hobs. A grid panel is certainly not the norm.
What happens in foreign countries is of course irreverent, but must be a pain with isolators for every TV, table lamp etc if what you say is true.
Reply to Where to put sockets? in the UK Electrical Forum area at ElectriciansForums.net
Hi, my friend is having a floating shelf with a electric fire, and I’m between minds where to put the socket, I was gonna put the socket behind...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
