Discuss where to switch a 12v LED circuit? in the Lighting Forum area at ElectriciansForums.net
Hi all. new to this and hoping someone can pity on me!
I've bought a LED light tape kit which comes with a 3pin 12v transformer.
I plan to put the LEDs to back-light a mirror on the wife's bedside table (she looks better in dim light!!!! :)
The transformer will plug straight into a normal 3 pin socket but that's behind the bed so I need to wire in a switch. so here's my question, do I need to have the switch on the 240v side (between the socket and the transformer) , or could I put a 12v 20amp toggle switch between the transformer and the LED tape. the second route would be much neater if it worked technically. so to be clear, the transformer would be permanently plugged in and live, but power would be switched on the 12v dc side of the circuit.
thanks guys
Transformers tend to get warm when left powered up with an open secondary. However with the size of it, probably not an issue.
Both would work.
You could put the switch in either the mains or ELV side of the LED power supply.
IKEA (and others) have the switching on the ELV side. As an electrician, my training tells me that switching the 230V power off is better and safer.
Reply to where to switch a 12v LED circuit? in the Lighting Forum area at ElectriciansForums.net
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
I have installed a number of 120v smart light switches and smart bulbs which I have set up on a schedule via an app. I would like to add another...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hello. I’ve been racking my brain all day with this. Here is my situation and question: I have some OEM ambient lights in my vehicle. They are...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
