AJ16
Can anyone recommend a 7.5W LED GU10? I was using a Sylvania lamp but it's no longer produced. The 5W ones are not quite bright enough for my bathroom.
Don't use the Robus 650(?) Lumen ones from Screwfix. They cost around £12.00 each and yes they are bright, but are also seemingly prone to failure. Two out of four failed within six months.
So more like screw ed unfix?! Philips or Megaman lamps always work for me
Never buy nowt from them, it's like buying from B&Q with aspirations of being a grown up!
I'll second Megaman after recent advice from this forum.
They do a 6 and 7W LED, I got them online from Fastlec, really good service, ordered online got them 2 days later. You would be hard pressed to find them cheaper.
Looks good, I'm after warm white but bright, I see the Megaman 6W warm white one is 2800K 'very warm white'. Just wondering if they would give the same light as a 50W dichroic??
Sylvania got back to me yesterday to say that they the 7.5W has been replaced by a 5.5W which is brighter, they are sending one for free to replace one that failed on Sat, so will be interested to see what it's like. It's called a RefLED Superia ES50 V2
I'm hoping the new Sylvania one will be good although not sure on pricing. What is the position now on dimming GU10 LEDs? Do you still need a minimum number to give best results?
I've installed 60 lumilife GU10's from LED hut and the customer is well impressed. 5W and they're bright. First time I've used them. 13 of them are on dimmer switches which I have to replace to LED compatible dimmers. LED hut recommend varilight pro dimmers so will see how they fair. Anyone used them?
ledhut sell dimmers on there site as well as the modules so you can use the same brand switch around the home
No I tried it on all the different settings and hums on each one. So there is 3 dimmers in the room. 5 leds on one 3 on the other and 2 on the other. All 5.7w
Normally a trailing edge dimmer should be silent you have not got it set to leading edge have you?
there are different modes on the varilight dimmers, have a look on there site there is a video guide that explains it i recon its probably in the wrong mode
8. My LED lamps are buzzing whilst the dimmer is on
This behaviour can be attributed to a component within the LED lamps themselves vibrating during operation. Changing the driving mode on the dimmer may improve this behaviour. Instructions on how to change the driving mode are located in the product instruction manual and on Varilight TV.
If the LED lamps continue to buzz after trying the different driving modes we would recommend contacting the LED manufacturer for further advice.
did you buy dimable led's? they sell both but the dimable are more expensive
Yes I bought the dimmable ones. I followed the instructions and changed the modes 3 different modes. I will try again in case I maybe haven't done it right. Will be back after the holidays so will update you.
Sylvania sent their 5.5W superbright LED GU10, the light is same as a 50W halogen, the old 7.5W is brighter and whiter- great in a bathroom, so I'm going for the 7W Megaman from Fastlec (thanks Vitesse). They are 550LM so should pack a punch.
£9 for Aurora FR d/light with 5W LED is great value as well there.
AJ16
Which LED GU10?
AJ16,
AJ16,
