A
Apesbrain
I have a fluorescent desk lamp that recently developed a problem: it will turn on first thing in the AM, but by the time I've gone to make my coffee and return it is off. If I switch it off and wait 10 minutes, it will often come back on but this cycle may need to be repeated a few times before it will stay on for the day.
It is a bit of a bother to disassemble this lamp, so I'm asking if the first suspect for replacement is the bulb (a square 4-pin tube) or the ballast? The bulb is about 3 years old; the ballast around 10 years (when I first needed to replace it.) Thanks.
Replace the lamp.
wont do any harm to try.
Replace the lamp.
The "lamp" or the "bulb"? I'd like to keep the lamp (fixture).
I got a new ballast today and replacement bulb (28W GR10q 4-pin) is on the way. Since bulb won't arrive for a few weeks, I'll probably replace the ballast and see if that fixes the issue.
A “bulb” is what I meant by lamp.
And after many years of working with Joe Public this is why I just call them a "bulb" these days lol
Nothing wrong with calling them light bulbs.
Like some do with starter motors for 5ft fluorescent bulbs?
Reactions: westward10
A 2D LED replacement panel would solve the OP's problem, whether it's the ballast or lamp that is faulty.
Reactions: DPG
Come on brian, it's a bulb.....
  • Funny
Reactions: DPG
Incandescent bulb, but fluorescent lamp. To be a bulb, it's got to be bulb shaped.
Reactions: Fazz711
Fluorescent tubes are tubers, similar to bulbs.
When are we going to get a 'groan' emoji?
They don't seem to be working....or I'd have used one for your informative 'bulb shaped' comment....( and for a wink on this one).
Reactions: DPG
Anyway... It was the ballast. 10 years seems like the limit on these.
Glad you got it sorted. Sorry, we got a bit distracted!
I had the same table lamp, and I went through this problem. At first, I replaced the tube itself: it was brighter, but it is dim again after a couple of turns. Then I took the body apart and checked the ballast - the plastic was warm and there was a slight squeak. I put a new electronic ballast and returned the old lamp to its place, for a year without failures. So I would suspect ballast first; if there is a spare lamp on hand, quickly eliminate it, but ten-year-old ballast, in my experience, is reliable.
Why fluorescent lamp won't stay on?
Lighting Forum
Thread Tags
Apesbrain,
DefyG,
