Discuss wireless cctv in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
customers after wireless cctv but with record and remote access
a kit like this decent???.... 4 Camera Digital Wireless Security System with 1TB CCTV DVR - https://www.spycameracctv.com/spycamera/4-camera-digital-wireless-security-system-1tb-cctv-dvr
only need the 3 cameras not the 4th.....can 3cameras link to only the 2 receivers? surely i need 3 receivers for 3cams as they will all be diff channels no?
also does anyone know a simular setup to this but with dome cams instead of bullet?
look forward to your advise
I'm my limited experiencewith wireless is that it's pants. If someone wants/needs cctv then it needs to just work. Wanting remote access with wireless kit will give you another weak link imo.
And the spec on them cams are terrible. Hope you don't want to see anything in detail during the day or anything at all at night. VERY over priced.
Use proper kit and use Poe.
The lunatic is in my head.
You raise the blade, you make the change
You re-arrange me 'til I'm sane.
You lock the door
And throw away the key
There's someone in my head but it's not me.
that's my take on wireless cameras.
Reply to wireless cctv in the UK Electrical Forum area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Hi all, this one is for the cctv gurus Installing a cctv system with 14 HiKVision is cameras. 13 of which are via wireless bridges as it is a...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
Hi all, I'm looking to install a basic (2 or 3 camera) home CCTV system. Having done some research I gather a lot of the wireless systems aren't...
