Discuss wiring chandelier with LED drivers in the The Welcome Forum area at ElectriciansForums.net
Hi, I'm a DIY / home owner that has a bit of wiring knowledge but has not wired LED drivers before. I have a chandelier that has 36 hanging bulbs / wires (G4 LED / 12 V, 1.5W each). The unit comes with 3 LED drivers, constant voltage that each support up to 24W. Nothing is wired together.
Basically I have 36 2-wire cables that should be at 12V.
3 LED drivers that have a 2-wire white / black cable for incoming 120 V and white / red 12V on the other side.
And 120 volts at the chandelier.
Any advice on how to wire it from the 120V to the 3 LED constant voltage drivers..
and from the 3 LED drivers to the 36 bulbs (perhaps 12 per driver).
Should I just wirenut together the 120v incoming black to the black of all 3 LED drivers and the load (white) to the white on the frontside
and then on the other end of the LED drivers connect the red + to 12 of the bulbs + wires via a wirenut and then wirenut the white - to the other - from the bulb side..
Or should I be combining together the wires in some other fashion.
Reply to wiring chandelier with LED drivers in the The Welcome Forum area at ElectriciansForums.net
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
Hey folks, i work for a relatively small company, but we are doing some big jobs. And right our headache is taking over outdoor lighting...
Hello, my house was built in the 1950s and every time I look behind a wall plate the wiring isn’t how it’s shown in any DIY book I’ve read. I’m...
