I have a 2 led spotlight bar left over that i would like to stick some flex and a plug on instead of wiring into the lighting circuit. The bulbs are 5.5w each.
Am I ok using some 3 core 0.75 flex and a 3 amp plug that I already have or should I be putting a 5 amp fuse in the plug with that cable?
Cheers
Cheers
Will the connections at the light fitting be accessible without a tool or key? will they be enclosed in other words?
Kent
Wiring led spotlight bar
djp,
DPG,
