- Dec 16, 2017
- 1,004
- 962
- 688
- 59
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
- Business Name
- TechFix Services
OK so I thoughtfully and methodically bound all the 30 hots and neutrals together and then bound the hot and neutral from the feeder wire that goes up into the ceiling. When I connected the chandelier and tried to turn it on the switch sparked and fried? What do you think is going on???
So what happened to the electrician you said you would get to install it?
