brmorgan1991
Hello all,
I have limited electrical experience, but I know a lot of the basics. I wired a 50 amp outlet to my breaker to hook an RV up to. I also got a voltmeter to measure the amount of electricity usage the RV is consuming. I know for sure the outlet is wired correctly to the breaker.
Unfortunately, I couldn't find any specific info for how to wire the voltmeter to the outlet. My first attempt fried the voltmeter and blew the back off it, as shown in pic.
I used 16/4 wire to connect the voltmeter to the 50 amp outlet, which was clearly a mistake. In hindsight, it seems like a no brainer that was a bad idea. I connected the line, lead, ground, and neutral to the same corresponding spots on the outlet. The line, lead, ground, and neutral of the 10awg copper cable from the breaker is also connected to the corresponding spots on the outlet. i.e. there are 2 wires in each connection point: 1 from the voltmeter and 1 from the breaker. I know for sure that each wire matches up with the right connection point type, but I see now the dumb move was having 50 amps connect to a 16 gauge wire.
How would I go about wiring the voltmeter to the outlet correctly?
I can gladly post more pics if needed.
Thanks so much,
Brandon
Thanks so much,
Brandon
