Discuss Working out number of LED requirements in the UK Electrical Forum area at ElectriciansForums.net
Hi, yet another question, sorry guys. Just wondered when you guys are installing recessed LED light fittings in a domestic property, how do you work out how many LEd fittings are required and also what is a typical LUX requirement for typical rooms ie lounge, dining rooms etc. Would LUX requirement be different for other rooms. I've been looking at a table provided by ENLIGHT. They give a guide by square meterage of room, but go on to say about LUX requirements.
In my day options were....40w, 60w, 100w....occasionally dizzy heights of 150w.....and a standard fluo in the kitchen!
PS got 2 x ground floor rooms x approx 7m X 5m
its all down to beam angles ,lumen outputs and colour temperature , as well as the room deco , i know it sounds daft but if you install daylight led in a lounge thats blue it will make the room feel cold , old halogens had a narrow beam angle 35 Degrees so you get a spot on the floor , so you go for a spot light with a wide beam angle , and depending on the decor or room you then select colour temperature so a led spot with a 2800k colour temp will give you a warm feel and 4700 will give you a colder feel so to the question how do you work out how many you need easiest way is on paper scale the room on paper and position the lights on a drawing using the beam angles draw them in so from a single point on the ceiling 35 deg 60 deg 120 degree's cross them approximately 1/2 the way down the beams
and hope that none end up directly on a joist. :90:
Ha on that note..........joist are the Z type which are hollow and 600mm apart, which you think will give some flexibility in siting light fittings. But
the plumber has first fixed and installed 100m dia waste pipes which at some points are near to the ceiling. Looking at some led fittings from memory they appear to be about 100m + deep. Is that about the norm for LEd lighting?
Yes, but most require "breathing space" above....
Is the ceiling fitted?
Reply to Working out number of LED requirements in the UK Electrical Forum area at ElectriciansForums.net
Baja wiring harness LED light help. I've fitted a US Baja harness on my Australian FJ, but I need to replace the Baja harness switch setup so...
I have been asked by Trading Standards to carry out a report on some electrical work installed by another company (5 years ago). The 'new' wet...
My Current Setup (see image BEFORE.jpg): The wiring for my existing detached garage is shown (see image BEFORE.jpg). The house consumer unit...
Does anyone have a recommendation - preferably without needing a second mortgage - for some outdoor spotlights ? I've tried a number of options...
Hi everyone, My first post but straight in with a couple of issues. I'll start with a 6amp MCB that keeps tripping out relating to ground floor...
9K
