Discuss Working Out Spotlight Spacings in the UK Electrical Forum area at ElectriciansForums.net
Had a bit of a discussion today, so thought I'd ask on here. When working out spacings for spotlights what setup does everyone use? I know different lights have different outputs and require different spacings, I was just wondering what people use as a rule of thumb.
Cheers, Jim
As a rough guide on the requirements of CIBSE
Kitchen and living areas 200 – 300lux
Bathrooms, tolilets 150lux
Bedrooms 150lux + local task liighting
Corridors, hallways 100lux
Using 1M spacing gives 267lux average
Using 1.5M spacing gives 121lux average
Using 1.7M spacing gives 98 lux average
As a rough rule of thumb kitchens and living areas use 1M spacings. Bathrooms, toilets & bedrooms you can use 1.2M or possibly a bit more. And corridors, hallways etc. you can get away with 1.7M.
Obviously the above is a rough guide as other factors come in to play such as ceiling height, lamp type, wattage, kitchen cupboards etc but I find it a good rule of thumb when designing.
Or is the OP asking how to generally space down lights (taking their output into account).
For example, if I have decided the room needs 4 x luminaires in a square room measuring A by B, I would place 1/2 A between each and 1/4 A each from wall. Ditto for B axis. In kitchens, dimensions of wall units are deducted from A or B. Generalisation of course, and allowing for joists etc.
Ignore me if I'm barking up the wrong tree, most people do. :D
Reply to Working Out Spotlight Spacings in the UK Electrical Forum area at ElectriciansForums.net
Hi, sorry if this is the wrong place to ask, I am wondering about becoming an electrician of some form or another and thought to come to an...
Hi all, Just wondering what the general situation is with other people on smaller jobs, do you give a quote or estimate to the client before you...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
Hi all. In a bit of a situation which is starting to cause a fair bit of stress and figured maybe asking some silly questions here may help to...
