Discuss Working with wired fused ccu in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just wanted to get some opinions on the following...
Working in a bathroom conversion requiring supply for a shower pump, changing lights to downlight and power to a demister mirror.
House currently has an old CCU with wired fuses and no RCD's. And lighting circuit has no cpc.
For shower pump supply I thought using a SFCU with RCD.
For downlight with no cpc I presume I need to put N/A on cert for R1+R2 and Zs readings and add an advisory about upgrading wiring.
As for demister mirror, to be safe I was thinking of using a SFCU with RCD also.
Client assures me they are going to have a rewire but I want to make sure all my work is safe and up to regs without presuming a future upgrade to CCU.
Any thoughts?
Any thoughts?
Chris, why would your client, pay you to do the work you describe only to have it all pulled out when they say they are planning a rewire? seems like they are just wanting the work done and sid the rewire, watch yourself, could be a mess of trouble for you.
Reply to Working with wired fused ccu in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hey, I want to use an old xbox 360 PSU- 12V 175W output- for my 12V sup pump (pump/air compressor). When I connected the PSU to the pump...
Howdy All, just after a 2nd opinion as i'm doubting myself. I went to a property to look at replacing the ccu, I noticed what I thought was a...
