G
GreigM
Hi there,
Wondered if someone could advise as not good with electrics! I have an expensive Xmas tree which is pre lit. It decided not to light up a few days ago and not really sure what the problem is. I thought it may be the power/ transformer plug but can't seem to find a replacement anywhere or anything like it with the same spec or plugs/ pins.
It has the following written on it;
Golden Power
Model GP-SW310DC0258-IP44(UK)
INPUT: 100V-240V. - 50/60Hz
OUTPUT: 31V 258mA, 8W
Ive attached pics of the adaptor and the connector it uses. I can't seem to find anything that matches online when searching under all the references. Ive contacted both the tree manufacturer an d Golden Power but they haven't responded. Im not sure they will be able to help so hoping someone can advise on a work around or maybe something else to try if the adaptor isn't the issue?
Golden Power
