Discuss Y plan with additional two port valve in the Central Heating Systems area at ElectriciansForums.net
M
midgetman
Unvented y plan system with additional 2 port valve overheat protection. I'm trying to find a wiring diagram for this set up. Has anyone got one please?
note: If the boiler has pump over run it will need connection to the pump live terminal within boiler instead of to the oranges of the valves like it shows in the diagram.
Edit: The line isn't complete between 2 on the cylinder thermostat and terminal 14 on wiring centre so draw that on if you print it off.
Reply to Y plan with additional two port valve in the Central Heating Systems area at ElectriciansForums.net
I had to wire in an extra 2 port valve today to protect a newly installed unvented cylinder (replacing the old gravity fed one) in a standard Y...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
(Or that might be should a failed HW valve keep boiler running) Woke up this morning to find the boiler still running even though all timers off...
For the past few years, I have used a hydronic system (outdoor wood boiler) with both high and low temp working simultaneously. The low temp...
